Flip the direction of wires in Creo Parametric ( Cabling)
When wires/cables/network is routed through datum axis ( location points ), we need an easy way to flip the direction of wires in Creo Parametric.
History
In Wildfire 4.0 there was an easy option to flip the wires. Please below.
From Wildfire 5.0 on words, this functionality is missing. Users reed to add the location points and drag the wires.
12 Comments
ssircar
To be able to flip, now requires extra clicks and more steps. The cable has to be first created and then the location redefined.
Users working on cabling are finding this very frustrating ...... imagine creating 50 cables and then redefining the location to reverse the direction (non-productive).
JimBarrettSmith
This video shows how to flip prior to along axis.  The red section of the wire indicates which segment the next location will placed next, so you know when to flip direction
Video Link : 7290
JimBarrettSmith
This video shows how to use the undo if you do happen to go in the wrong direction
Video Link : 7293
I hope the videos help
TajuJoseph
6-Contributor
Thanks Jim
Appreciate your help
Regards
Taju Joseph
Leap Australia
TajuJoseph
6-Contributor
Is it a new enhancement in Creo 4.0
Regards
Taju Joseph
JimBarrettSmith
Hi Taju
Introduced in Creo 1
thanks, Jim
TajuJoseph
6-Contributor
Thanks Jim
BrianHale
6-Contributor
 Can the videos be re-uploaded or put somewhere else? The links don't seem to work.
Brian
StephenW
23-Emerald II
So many of the links to videos didn't come over correctly when the forum was moved last year.
I notified the moderator to see if these could be corrected. Check back next week to see if they magically re-appeared.
BrianHale
6-Contributor
 Thanks!
PTCModerator
Emeritus
Status changed to: Current Functionality
DC_10087765
1-Newbie
Link appears broken again. Can these video links be repaired?
