Option for the Model Player Window: Force the regeneration of failed system features (Topological System References).
Topological system failed features are often not related to the origin failure (not dimensioned referenced) and can be recovered by an "edit and validate" action.
Forcing the regeneration of failed "system features" avoid's an “edit and validate” action on all the features.
