Within a part with repeated geometry it is possible to define one instance as a formelement and then to propagate this formelement.
However, when the part is stored it occupies more disk space than the part with repeated geometry.
An alternative is to define the geometry that is to be propagated as a separate part and then to propagate this part.
This technique for reducing the disk space required for repeated parts should also apply to formelements within a part.
