From Creo Parametric assembly, how to generate external solid subset without internal geometry
With Creo Parametric 2.0, from an assembly with complex component geometry, it is currently not possible to create directly an envelop or shrinkwrap as solid with fill hole attribute and without internal geometry or topology.
Using Create Envelop with different options like Surface Subset Shrinkwrap  or All Solid Surface Subset Shrinkwrap with attributes Auto Hole Filling Include Quilts allowed to get a solid part with correct external shape but also with internal solid geometry or topology.
Instead of internal solid geometry or topology, we need to get the envelop filled of material.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
