Full UNDO & REDO for Creo Parametric DRAWING mode
Currently, many actions done in DRAWING mode cannot be undone.
DRAWING mode should have full UNDO & REDO capability for all operations!
8 Comments
wjamieson
Is there any way to turn on Undo & Redo in drawing mode currently?  Any help is very appreciated!
AndyHermanson
What version are you running? Creo 3.0 has fixed most of the missing undo/redo issues. It may be worth taking a look.
wjamieson
We are currently running Creo 2.0.  We should be upgrading to 3.0 soon, and I look forward to seeing the improvements!  Thanks for the info.
mhayashida
3-Visitor
Even in Creo3, UNDO do not implemented for drag move of the end point of line entity. (Possible to UNDO for drag move of line entity itself.)
PTCModerator
Emeritus
Mfridman
Status changed to: Implementation In Progress
Hi all,
Many of the commands have been already updated to support undo/redo, however this is an ongoing process and we gradually continue and add this capability for each area that we modernize.
Updating the status to "Implementation in progress", since it best describes the situation of this product idea
kamleshjoshi
Will it be implemented in Creo 9
Mfridman
Hi @kamleshjoshi
As mentioned above, this is an ongoing process. for every new capability that we are adding, we are taking care of the undo/redo aspect.
In addition we have on the roadmap to align the same support for existing capabilities that do not have this implemented yet
