Full screen and Normal to----Set view orientation
Normal to----Set view orientation Normal to the selected plane,planar face or feature
These two functionalities are high used in design and available in Solidworks and other software.
13 Comments
DavorGranic
You can do this via view manager - define view normal to face/plane. im guessing you want it with less clicks. maybe macro would help?
tshen
Normal to----Set view orientation will be enhanced in Creo Parametric 3.0.
If you minimize the ribbon in Creo 1.0-2.0, the window size is near to full screen.
ptc-4226637
1-Newbie
If it is true for creo 3.0,  this is really a great enhancement.
NicolasBourgeoi1
Hello Davor,
Can you share a print screen of "define view normal to face/plane" ?
Thanks.
Nicolas
tshen
Hi Nicolas,
Please refer to the following article for detail:
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS127658
NicolasBourgeoi1
Hello
This functionality was long awaited.
I think you can switch the idea http://communities.ptc.com/ideas/2555  to “Implementation In Progress”
Thank you for the confirmation that the functionality will be available in Creo 3.0
DavorGranic
Nicholas, it seems I misunderstood "normal to"  - looking at your icon there. XD
NicolasBourgeoi1
no problem 😉
Good news for Creo 3.0
Nicolas
ptc-5127287
1-Newbie
Full screen functionality  is in Implementation In Progress  too, or only for view normal?
dbreda
1-Newbie
Hi Frank,
Implementation is in progress for View Normal To, not for Full Screen. However, as Tao Sheng Shen mentioned above, You can minimize the Ribbon in Creo 2.0 to get very close to full screen functionality in Creo 2.0.
Don
NicolasBourgeoi1
Same commands that allow to minimize the Ribbon:
- Ctrl+F1
- Double-click on tabs of the Ribon
- Arrow on the top left side of the Ribon (like illustrated by Don)
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
