Function in Mechanism (MDO) respect different variables
0 Kudos
I intend the possibility to insert a function (both by points/sketch graph and analytical expression) that can be used inside servo/torque motor and measure definitions.
Example: I have the torque curve respect time (or shaft angle) of the system defined in the "configuration A". I can export that curve like points file. Now I pass to the "configuration B" and I want to see the differences because, based on spread between the two ones, I want sistem B reacts in some manner. How can you insert the "configuration A datas" inside the "configuration B formulas"? Now you can use in formulas only datas from measures obtained from the actual analysis.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
