Enable users to design Class A Surfaces/Quilt constraining curves and surfaces at desired curvature degree.
A bezier curve functionality and the surface mesh definition (Some of the old ICEM functionality) should be introduced in the Style feature.
Today you must define your design with some style feature and rebuild the geometry with Reverse Engineering Xtension (Quite similar to the icem tools mentioned before).
Please integrate them in an Automotive package!!
