Many times engineers creates on the machineries assemblies which rarely changes.
This can be the case of functional groups or company standard groups, commercial… etc.
In many cases this kind of assemblies are not unite for bill of material reasons or for unusual
modifications.
Will be helpful to give to the user the opportunity to set an assembly as “glued”, in this way it will be
selected simply by a click on viewport for position and other ncommands.
Program will select directly the assembly (not the parts
contained) in every command by default.
When needed to modify, the assembly can be unlocked again.
