Gas/Air/fluid element
0 Kudos
Can we have a fluid element?
A sealed container filled with a fluid is then subjected to an external load.
The fluid pressure rises uniformaly (ignoring gravity for the moment) and the structure as to respond accordingly
There is NO fluid motion, this is not fluid dynamics, this is a static solution.
This should work with assemblies.
