A Creo-Illustrate sequence should be able to be played from beginning to end in one long animation.
Sequencer and Animator are two totally separate operations within Illustrate that cannot operate together in the same file... Why can't they be combined?
TWO separate files have to be created to have BOTH a sequence and an animation of the same process.
