1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Marine - harnesses for engines and boats
2. What version of Creo Parametric are you currently running?
5 moving to 8 in a few months
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
In my 3d harness, i have small sub assys (components that are routed to) that are flexed. when i open the harness mfg module they are unflexed ( and cannot be flexed). can the you get the harness mfg module to be able to show a flexible state of a component?
In the 3D state this sub assy is flexible ( suppressing other items)
and in harness mfg i see this
4. What is the use case for your organization? designing harnesses
5. What business value would your suggestion represent for your organization? speed up time to generate harnesses
