Ideally this should be the default because if you have it set by mistake, it is easy to fix by using the "Unshare" command on all items that shouldn't be shares. If that option is off (like the default is now) by mistake, it is VERY DIFFICULT to fix this later-there isn't a good way to take a copy of a part and make it a share instead; the only option is to start over.
