The first sheet of a DRAWING usually has a long string of notes on one side to describe various specifications and conditions for a part and the standards used in the drawing. Currently, paragraph formatting and numbering is done manually.
For these notes, it would be very helpful if more advanced word processing capabilities were built into the text editor; in particular: Bullets & Numbering and Paragraph Indents.
Besides having different bullet shapes and numbering types, within the SAME text box/multi-line text:
a. bullet types and numbering should be changeable partway,
b. numbering should be resettable partway,
c. indents, bullets/numbering toggled on and off,
d. indent spacing and amount of indents should be changeable partway.
example start>
Notes:
1. numbering type 1, sequence 1
2. numbering type 1, sequence 1
i. numbering type 2, sequence 2
<spacing added to draw in symbol or GD&T boxes>
ii. numbering type 2, sequence 2
iii. numbering type 2, sequence 2
2nd paragraph continues.......
2nd paragraph continues (auto wrap with indent).......
3. numbering type 1, sequence 1
4. numbering type 1, sequence 1
a) numbering type 3, sequence 3
b) numbering type 3, sequence 3
c) numbering type 3, sequence 3
< example end
