I would like to have both mechanism connections and normal constraints in an assembly. I know we cant make them in single set. How ever Creo was able to create different sets of constraints. Why shouldnt we have 2 sets created one for normal constraints and the other for mechanism connections. And high level assembly must have option to swap between sets so that all components will change to set 1 or set 2 as required.
