Hide/show component during animation with ProToolkit
0 Kudos
Is it possible during batch animation to "hide" or "making not visible" some component? ProAnimobjectCreate ProAnimframeObjAdd permits to move some components during animation. The components not included in the frames remains steady but still visible. The goal is to "hide" some components during the animation.
2 Comments
TomD.inPDX
I don't know if it helps, but you can use Style in animations to change states of components during animations.  You can change things to wireframe or even transparent, along with blanking.  The only limitation I found is that you cannot have colors assigned surfaces because this will cause style to ignore those surfaces.
olivierlp
Community Manager
Status changed to: Archived
