I thing a good evolution would be to hide the 360° dimension when you create a full revolve feature. Or maybe having the choice beetween a 360°dimension or not.
Currently,when you want to show dimensions from your 3D model if you have created it with some revolves you have to be carefull to do not show your 360° dimension on your drawing.
I understand that a non full 360° ex:45° need a dimension but I don't think that a 360° is needed anymore.
A choice will be interresting for users who wants to create relations /pattern or automatisation...Other users are not interrest by this.
I thing It cames from old Proe version for radial pattern using 360/Nbre = increment.
