Highlight feature in graphic window when selected in model tree regardless of display filter state
Currently if your datum display filters are turned off when you select a datum feature in the model tree you will not see the feature highlight in the graphics window. I would like an option to be able to see the highlighted feature in graphics window when selected from the model tree regardless of display filter state.
1 Comment
mneumueller
Status changed to: Current Functionality
this should work in more recent Creo Parametric versions. Which version are you using?
