Hole Label must have Leader option to represent Holes while creating Hole Table in drawing. Now while creating Hole table , we have only Hole Upper right and Hole center as position for hole label. If we have more holes which are very near , it is very clumsy and it is difficult to understand the hole labels while placing the hole label as upper right or to the hole center. This Hole label for the leader origin should not be changed when we updated the hole table due to changes in 3d model. I have attached a simple dawning which shows hole label with leader to understand. We also suggest to have Save option for the table columns. Now we have to go and add parameters manually each time.
