Hole Table for specific hole types separately with an auto tangent leader from the Hole origin
Customers are in Mold industry and usually have a repeated requirement of creating specific sized hole features. However, when simple holes are created customer is unable to call the counter bore, counter sick and depth parameters in the drawing hole table. Customer has to manually define feature level relations to create required cbore dia, csink dia and hole depth parameters that get the values from respective feature dimensions. Customer states that this is causing extra work and delays in detailing process.
Currently we have below few limitations in the hole Table and request for enhancing the same
Hole Table has to be created for specific hole types separately with Hole label with Unique Alpha numeric or numeric scheme with Auto leader from the hole center origin. We have this capabilities in UG-NX . I have attached the sample drawing for reference and understanding the requirements.
Hole labels are not created from the hole origin automatically with tangent leader option.
Provision to mention the Hole Tolerance the hole Table
Provisions for save option of the hole Table column settings & parameters for reusing it later as and when required instead of every time adding parameters manually
5 Comments
SureshPerinjery
8-Gravel
Dear Product Managers,
This is a much required capability particularly in the tooling industry. Competition has it for many years and we are facing challenges with customer satisfaction in sales and renewal sales.
kamleshjoshi
Dear sir,
If this thing will be added then it will definitely create positive impact on the design, many times end users need to manage the overlapping labels.
rahulsardar1
6-Contributor
This funtionality is important when it comes for Tool room.Also we are seen less productive when compared with competition.So needed fuctionality.
kamleshjoshi
Hello product manager,
This is very essential capability and it should work in datum point and datum axes type also, because in general when we have the hole table using datum point then datum point tag not shown properly in the view, it is some distance away from the point location and many times create difficulties.point tag.JPG
Mfridman
