The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Hot keys - only single keys, really?
Yet another obvious head-scrather that makes no sense.  Right now you can only add hotkeys for functions that are single lower-case letters, with the exceptions of function keys.  Is there a reason at all that we cannot use a combination of modifier and letter keys, including upper case?  Once again, you can do this in other CAD systems, but are really limited with single hotkeys in ProE.
4 Comments
MartinHanak
24-Ruby II
Key Sequence entered during mapkey definition can contain several characters.
For example:
dpl ... display datum planes
dpo ... display datum planes
Combination dp is forbidden if dpl and dpo combinations are used.
ginashvili
1-Newbie
Hey Martin - I was actually aware of that, and thought those make even less sense than single key operation, typin a "word" in sequence to get a macro to work, which is why I didn't bring it up.  What they need to do is what other systems have done for a long time - allow simple modifier(s) + key combination.  Works like a charm.
BillRyan
"Single key operation" is what you are requesting, but your example requires pressing two keys "modifier + key combination".    Sounds like added complexity to me.
I have a mapkey called "ss" for save simplified rep.  It takes a second to move my finger to the s key and then hitting it again is in the hundredths of a second.
WIth my manufacturing cap on, having mapkeys specific to capital letters is not poka-yoked.  How many times am I going to hit the s key when it should have been an S?  I wouldn't want to invoke this failure mode into the process.
Another alternative is to create a mapkey and associate an icon to it, than add the icon to the ribbon.  The icons themselves are customizable also.
PTCModerator
Emeritus
Status changed to: Archived
