As a designer / planner, I want the drawing sheets to be named according to the FuBIT tables present thereon:
e.g. Edit pages 1-21 to find the tables more easily.
IST: currently the drawing sheets can only be named continuously with Toolkit.zB. Sheet6, Sheet7
Set: The sheets are named using the tables shown
Case: C12460571
Answer from PTC: Contacted Andrea and informed her that we do not have Pro/TOOLKIT functionality to name or
rename the drawing sheets. We can get the name with ProDrawingSheetNameGet(), but we don't have a
corresponding function ProDrawingSheetNameSet() or any other means to set the name. As always,
one may try with macro functionality used by the application.
