How to create diameter dimensions on a symmetry in the 3D model in the same way as in sketching
I am working on a CAD-CAM integration project and I want to use the Model Based Definition on Creo Parametric (drawingless).
In sketch, you can create diameter dimensions on a symmetry (3 clicks, axis, side and axis) for example a revolution. I try to reproduce the same technique to create a dimension (3D annotation) in the 3D model but it doesn't work - is there another solution?
4 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
olivierlp
Community Manager
Thank you for publishing your idea and welcome to the Community. We need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
I invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
YLocatelli
11-Garnet
Our organization is active in the field of construction machinery, combustion engines, and hydraulic components. I work in the IT department of the company, and we have a CAD-CAM integration project. We want to use the Model Based Definition on Creo Parametric (drawingless).
Currently, we use Creo Parametric 7
We want to integrate MBD into our construction and manufacturing methodologies
CAD-CAM integration, manufacturing and design process improvement
olivierlp
Community Manager
Hello @YLocatelli ,
Thank you for your idea and the information provided!
