Actually, if we want to know the total mass of a model in Simulate, taking into account on the beams, shells, and mass elements, it is necessary to run an analysis. The total mass is given by the study status file (.rpt), at the end of the calculation process. This can be (very) long, depending on the size of the model.
Is it possible to add a feature, able to calculate this total mass? Without running an analysis? This is available in most of the calculation software…
