I want to change the default command of created "split menu".
0 Kudos
Now need there is to recreate the "split menu".
Example
3 Comments
PeterKehoe
By definition, the default command for a "split menu" will be the last command activated, so it doesn't make any sense to specify a default command when creating the "split menu" since it will constantly change after that.
nhiroyama
1-Newbie
Added command later will not be the default.
Ver19.0 M010
olivierlp
Community Manager
Status changed to: Archived
