INHERITANCE FEATURE FOR ASSEMBLY SAME AS INHERITANCE FEATURE FOR PARTS.
POSSIBILITY TO SUPPRESS PARTS & TO CHANGE ASSEMBLIES DIMENSIONS.
We need this functionnality to decline assemblies wich contains differents parts (because of different grooves) but should be dependent to a master.
Today we a doing family tables.
CREO BOM should list the component of the Inheritance feature (components of the source assembly that have not been suppress by the user).
WTPart of the Inheritance assembly should be created and managed.
Careful with the WTPart of the source assembly: should not be affect by internal modifications of the inheritance feature.
(we use multi-owner links)
