INSTANCE COLUMN TO BE ADD IN ASEMBLY LAVEL
HELLO EVERY ONE ,
In Assembly level we are changing the names from A1 to A2, in the same way here we requires the renaming of instances names of parts automatically(Sheet Metal),
Here we are getting below problems:
1 For example in assembly we have 100 parts so, we are changing the names at every individual part. It is taking so much of time and It impacting cost.
2 If the part instance renaming is not done then the Drawing will not open.
For that there should be a column of instance name with renaming possibility.
3 Comments
mmonteiro
In the session must have the assembly and the drawing of the part instance.
ciclean
1-Newbie
yes it is having
PTCModerator
Emeritus
Status changed to: Archived
