The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Icons Move Between Modes
When I switch between Modes (Assembly, Part, Drawing, etc.), a different set of icons is displayed for each mode. Quite right too! However, many of these icons are common to all Modes - Datum Planes on/off, for example. What causes me some concern is that the common icons do not appear in the same place in all the Modes.
For example, in my incompetence/impatience, I will frequently switch from a Part window to the Assembly it is used in and only then remember that I have all the Datum Planes Shown. this makes the Assembly slow to appear and difficult to work with. I therefore do a 'Panic Press' of the Datum Planes display icon, only to find that, as part of the Mode change, the icons have shifted; when my Assembly appears, it not only has all the Datum Planes Shown, it also has all the Datum Axes Shown. All the icons moved one step to the left during the Mode change. The other common problem is with the 'Switch Dims' icon. I use this quite a lot in all 3 Modes (that reminds me of the Bar in the movie 'Blues Brothers', where they had 'Both kinds of music: Country AND Western!'). Sadly, the icon appears in a totally different place in each Mode.
Idea:
The software should figure out which icons are common across Modes and fix their positions to be the same in all modes. The variable icons can be fitted in wherever it is convenient.
This is a general observation about User Interfaces, I suppose. An icon that is always there should always be in the same place.
I do not have experience of Creo or WF5 (nor am I likely to for some considerable time yet), but I anticipate the scenario still applies.
Please vote up if you agree with me.
John
3 Comments
JonathanHodgson
11-Garnet
Me too!  My brain is rather bad at recognising icons by the image (I've been known to print a draft email when I actually wanted to save it ), and seems to work mostly on position.  Therefore, icons that jump about depending on mode confuse me and slow me down.
This is possibly why I like keyboard methods so much - they're always in the same place!
Failing that (although it's probably a Windows issue rather than software-specific), the system should recognise what was under my mouse when I clicked, not what's occupying that position ten seconds later when it finally gets round to acting on my click...  Or even just disable click buffering while it's re-drawing the toolbars.  I'd rather have it ignore my click completely, than activate the wrong command.
dhermosillo
@John sadly it does continue into the more recent versions, and is exacerbated by the ribbon, which completely ignores human's inate ability for spacial recognition.
I was reflecting today on a posting by PTC who was extolling the wonders of the command search box, which when you think about it, essentialy returns us to the text input that AutoCAD still allows.  Only the PTC method is less convenient.
PTCModerator
Emeritus
Status changed to: Archived
