Image Visibility On 3D model After Checking In To Windchill
It would be great if applied image on 3D model surface visible after check-in to windchill as well..
Currently applying image on 3D model surface can be done by two feature 1.) Image,  2.) Appearance, Though images added by these features  will be disappear once the 3D model checked in to windchill
2 Comments
Pearl
Config option save_texture_with_model controls saving images with the model.  The default is no.  Setting it to yes will embed the image in the model file.
Visitor
applied the image on model surface by changing config as mentioned but If we try to move/replace the image in the model and switch back to the drawing there is a fatal error and crashes Creo as shown in the below image.
please let me know if you have any suggestion.
