What does it mean submodeling in FEM:
Submodeling is a finite element technique used to get more accurate results in a region of your model.
Often in finite element analysis, the finite element mesh may be too coarse to produce satisfactory results in a region of interest, such as a stress concentration region. The results away from this region, however, may be adequate. To obtain more accurate results in such a region, you have two options:
Submodeling is also known as the cut-boundary displacement method or the specified boundary displacement method and it is based on St. Venant's principle. The cut boundary is the boundary of the submodel which represents a cut through the coarse model. Displacements calculated on the cut boundary of the coarse model are specified as boundary conditions for the submodel.
The majority of high-end FEM codes allow this technique; use the following link to see an example:
https://www.youtube.com/watch?v=bf1Que-d4DE
