Import of ProE/Creo files in CreoElementsDirect with optional precision
Problem:
Importing ProE/Creo files with the precision of the part is from ProE/Creo is often low. For further work this often is a problem (for example importing a sheet metal and generating a flat projection).
Workaround is Export in Stp and Import with higher precision.
Ideally woul be the possibility to adjust optional precision during Import od ProE/Creo files.
Thomas Schad
Fa. Scirotec
1 Comment
olivierlp
Community Manager
Status changed to: Archived
