Import parameters from STEP file - even when they match existing parameter names
Parameter values from a STEP file fail to import if 'use templates' is enabled and the template model contains matching parameter names. The whole point of using template models is to make sure that all planes, views, and parameters exist in every model. Using a template during import shouldn't block the parameter values from being transferred in.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
