Imprinting should happen within single Part in ProMechModel
1. ProMechModel does imprinting correctly when there is an assembly with separate parts in it.
2. When there is single part (*.prt) then imprinting does not happen.
3. Please check attached single part and presentation describing the problem.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @amol_patil for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration. As an example, here is a Creo well documented idea: Make Shrinkwrap quality more scalable to data size... - PTC Community
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
amol_patil
6-Contributor
We (Novus Nexus) is technical partner to PTC. We developed automation CAE product-CAENexus as an addin/Auxiliary application over Creo using Pro/toolkit API. Our product has been used by some of our common customers using Creo. This issue has been originally reported by John Deere.  I am working as software developer and support engineer for CAENexus.
Creo 7.0
CAENexus creates simulation model (imprinted model) as ProToolkit's ProMechModel. The ProMechModel created using Pro/Toolkit API fails to imprint the edges for a single part as shown in attached presentation. ProMechModel gives imprinted edges if we create two separate parts (.prt) and include them under assembly. However it is always not advisable to create two sperate parts from design point of view.
As these edges are not imprinted, they come as overlapping edges in non-manifold model built over ProMechModel. These overlapping edges creates problem for meshing as CAENexus meshes non-manifold model.
If ProMechModel imprints the edges within single part then Deere CAD engineer need not to create two parts or they need not to do unnecessary CAD modification such as creating distance between these edges in native Creo model. It will save CAD engineer's time.
--No need to check CAD once mesh fails due to edges being not imprinted.
--It will save CAD engineers time making simulation process automatic and flawless.
olivierlp
Community Manager
Thank you @amol_patil for your additional info. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
