Measuring a distance between two surfaces
The current CREO distance Analysis tool behavior: The result display jumps always to a a norner or to the calculated Center of the first surface feature. Shown as "1" in the picture
The behavior should be: The Position of the Analysis should reference the point position selected-first, shown as "2" in the picture.
With reference to another issue: The result Icon should be placed close to the Dimension line https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS99635
