Improve Measure Tool
As-is, the dimension sometimes pops up behind the measure dialogue box, it would be better if it didn't so you wouldn't have to move the dialogue box to find the measurement.  Also, not having to hold the Ctrl key to select two items would be helpful.  Another enhancement would be to be able to escape the measure tool using the middle mouse button.
6 Comments
cruf
6-Contributor
I think it would also add a lot if the measure tool could also display by default:
Min Distance
Max Distance
X offest
Y offset
Z offset
Solidworks does this and it is extremely helpful.  Instead of having to pick which type of measurement output you want it just gives you everything by default and you can set it up to show this in both metric and english at the same time too.
ChristopherLewi
9-Granite
we've seen users confused at measure for sure. i can't say i can think of a better solution than to throw away the need to use cntl key though.
MarcVerschelde
3-Visitor
Please allow the option to have the Wildfire 4.0 measuring tool because the CTRL button is not needed and the projected distances are displayed in different colors
dcookson
1-Newbie
The measure tool is awful.  As stated the dialog box is sometimes obstructed and the difficulty in finding orthogonal dimensions is ridiculous.
PTCModerator
Emeritus
ToddKraft
Status changed to: Under Consideration
Improvement to the current measuring tool is under consideration.
Thank you for your input,
Todd Kraft
Creo Product Manager
