Actual functionality of SHEET_SIZE_INFO (Sheet Size Information) lists the number of sheets in the drawing and their respective sizes.
We have a need to identify if different format sizes are used in the drawing to keep consistence with some of our internal processes that require that all sheet size are the same.
Either to modify the current check SHEET_SIZE_INFO or to create a new one that mark an Error or Warning if different size sheets are used in the same drawing.
