Improve application display with High DPI display
Currently Creo Parametric 2.0, 3.0 do not handle high dpi displays well. These will only become more prevalent going forward and a decent solution is needed. Maybe a config.pro could be added to control text size in the browser?
6 Comments
Topaz II
Robert Myers
You may want to vote on your own idea...
Participant
Thanks for the heads up, I'm never going to remember to do that. Yet another feature enhancement needed.
Topaz II
Guest
Great idea.  This should get a lot more votes.
Topaz II
Here is a discussion about this idea:
https://www.ptcusercommunity.com/message/467963?et=watches.email.thread#467963
Maybe is has been fixed in Creo 4.0 as mentioned.
Alexandrite
Hi all,
PTC is planning to officially support HDPI Display monitors within a maintenance build of Creo Parametric 4.0.  The platform support documentation will be updated and reflect this support when released.
At this time, we have not committed to backport this support to Creo 3.0 or Creo 2.0.  Running Windows display at 200% (default) will avoid potential problems encountered in those releases.
Mark
