Improve management of the destination when creating geometric tolerance / datum feature symbol
  1. Better management of the Destination when creating a geometric tolerance in the drawing.
    1. Destination setting must be more clear and managed as more relevant option.
    2. Possibility to define a default destination in the drawing (e.g. new feature Set Default destination).
    3. Option in the config.pro to e.g. define that the default destination is the active drawing model or the drawing.
    4. Clearly display the destination e.g. at the bottom of the screen next to the sheet size.
    5. Possibility to define as destination a base model of an Merge / Inheritance feature.
      1. This option implies that the base model is automatically loaded in session.
1 Comment
Mfridman
Hi @cbertschy,
I would like to point out that some of the above listed capabilities are already supported for gtol annotation type (not yet for DFS):
  • We have the following config.pro option to control the default owner (destination) of the gtol, when placed from the drawing - the option name is "default_gtol_owned_by_model"
  • When your "annotate" tab is active, you can select a specific gtol from the graphics area and find in the drawing tree the owner of that gtol (see image)
Best regards,
Michael
