Improve measuring command
Seems like this should be in the "Creo modeling" community, but it doesn't appear to allow Project Ideas there.
Although mentioning SolidWorks isn't the most polite thing to do, please take a look at how it works. It just seems faster, requiring fewer clicks, and easier.
1. Make an option to show two units at once.
2. Single click selections.
3. Clicking in space clears selection.
4. Automatically show x,y,z distances in results pop-up (not having to switch sub-tools).
(It's also noted somewhere else about the pop-up going behind the Summary window needing to be fixed.)
https://www.youtube.com/watch?v=j9_AuEZPcro
3 Comments
rohit_rajan
uptil creo elements 5.0 it was good...showing measured dimensions behaved very similar to solidworks...with different color lines.
but it was removed from creo parametric onwards..why??????????????????/
now i have look at the coordinate system to understand which dimension is showing which axes...
ptc-5589582
1-Newbie
FYI: Jeremy, you can vote for your own idea.
olivierlp
Community Manager
Status changed to: Archived
