For TEXT Notes in DRAWING: "Box" currently affects the line spacing. This makes sentences look uneven when "Box" is partially applied in a multi-line text box.
Please add the option for "Box" not to affect the Line spacing. Perhaps the enclosed text can be made slightly smaller so that the box maintains the same height as the rest of the text.
Also, please add more shape options to enclose text with. Eg: circle, oval, capsule (box with sides fully rounded, used for dimension numbering/IDs), triangle (used as rev triangles highlighting where changes were made in a new revision of a drawing), flag, polygon, etc.
If possible, the outline color and thickness, with and without fill colors (or color gradient), should be customizable as well.
Moreover, text formatting options should be added to PART mode SKETCH as well.
