For TEXT Notes in DRAWING: "Superscript" & "Subscript" currently affect the line spacing. This makes sentences look uneven in a multi-line text box.
Furthermore, "Superscript" & "Subscript" seems to only lift and depress, respectively, the position of the text; it does NOT make the text a smaller size.
Line spacing should NOT be affected and "Superscript" & "Subscript" text should be smaller than the main text.
Moreover, formatting options for "Superscript", "Subscript" should be added to PART mode SKETCHER Text.
