We don't want to give the possibility to create Varied Items in this case. The base model must remain the absolute reference.
More simple, we need the benefit of the Ext Inheritance Cut Out, Merge or Intersect feature to show annotations but without the ability to create Varied Items.
Base Model used as reference to create the Merge / Inheritance feature.
Final Model with External Cut out, not possible to show annotations from base Model.
Final Model with Ext inheritance Cut Out, possible to show annotations from Base Model.
Drawing of Final Model, not possible to show geometric tolerance attached to the dimension in the base model because of External Cut Out feature.
Drawing of Final Model, possible to show geometrical tolerance attached to a dimension in the base model because of Ext Inheritance Cut Out feature.
