Improve useability of Drawing Templates
Irritant:  System Parameter (specifically PTC_WM_REVISION) when used in a Drawing Template turns to hard coded text when a Drawing is created from a Template.
There are support articles that state this is intended functionality (?!).
The recommended workarounds of reloading the format after the drawing is uploaded seem clunky and unnecessary.
Please change the Product Specification to fix this (yes - as a long time user, I view this as a bug and/or invalid specification).
System Parameters, Drawing Formats and Drawing Templates all seem to be intended functionality, so why would the product specification not support a seamless workflow in utilizing these intended functionalities?
Desired Result:  To be able to create a new drawing from template or empty with format without having the parameter change to hard coded text or requiring users to reload the format after uploading.
