Improved Alt key function in drawings
The Alt key + rectangle selection functions in CreoParametric 4.0 drawing can be used to select objects other than those that can be selected in the active tab.This function is very difficult to use.
Please change the function of Alt key + rectangle selection to the function that can select all like CreoParametric2.0.
1 Comment
MarcVerschelde
3-Visitor
For Creo Parametric 2D drawings, a config.pro option should be available to enable
selection of Everything in the drawing, independent of the 'active' Ribbon Tab.
This was default behavior up to Pro/E Wildfire 4.0 and it was at least 25% faster
and easier.
