Improved global clearance check results (Exclude 0mm clearance)
Pro/E should be able to check parts that clearance is between specifed numbers, such as between 0 to 0.1
0mm clearance is included in the result today, but should be excluded. Very difficult to understand the result.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
