The purpose is to switch from the ProE font.ndx/stroked stick font to a modern font. This helps with:
- WYSIWYG Exporting while maintaining real searchable/editable text...especially for PDFs
- Creo4 essentially disabled font thickness control (except for entire notes) while the new Bold feature doesn't visibly bold for the stroked font styles.
- General downstream reuse is impaired by using a stroked font instead of a modern universal font.
It should at least have the following features/compatibility:
According to the standard, it should be:
- All caps with exceptions
- Gothic/Sanserif (without flourishes)
- Single stroke (all letters are the same thickness everywhere in the letter)
To be useable it should also be:
- Monospaced (spaces and letters take up the same space)...this is essential for readability for text alignment and tables on Engineering drawings)
- Comprehensively changed and controllable with config options
- MBD compatible (ideally updateable with dwg config or mapkey-able from drawing)
- Symbol compatible (diameter, degree, etc)
- Whatever font is used it should be either universally present or embedded. Not a big problem for Creo because startup scripts can distribute, so this is mainly for other applications (Creo View, pdf, dxf, etc).
- Nice to haves
- Ideally, this font should be especially easily legable with All Caps but also lower case.
- 100% differentiable between letters and numbers (e.g. Il1 = iL1, etc)
- A text style checkbox like in word to switch between sentence case, title case, all caps, Small caps)
Great discussion on this:
Please comment if I may have missed anything.
