When you create an Inheritance Feature, all the entities that were contained in a layer in the base model, in the inherited model are all visible and not contained in any layer. Moreover the user is not allowed to put any feature contained within the inheritance feature in a layer (CREO warns you that "Cannot select feature from Inherited model in this context").
This affect negatively the view management display (expecially in drawing mode).
It would be usefull if the inherited model could inherit also the layer structure in some way (as a subnode layer, for example).
