Inseparable_Assembly of PCB's and Cabling-assembly's and also may keep the original Model-ID and MM-Id
Using PCB or Cabling you'll get a lot of parts and assembly, therefore it would be a good idea to make them inseparable. At the moment this is only possible by Unlocking the Assembly's.
But there is a problem modifying later the pcb or the cabling because DirectModeling looses the ID's and MM-Number when the assembly ist made inseparable. Making it later separable you have only new parts and assembly's and you cannnot actualize the assembly's
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
