Insert template sub assemblies like UDF
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
We design metal stamping die designs
2. What version of Creo Parametric are you currently running?
CREO 7.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
While designing, we have several templates, that we add to our designs as sub assemblies. To proper fit those templates, we need to relate to skeleton's planes, axis, surfaces, for that, we need to create copies and replace the references, to the new created copies.
4. What is the use case for your organization?
Our proposal, is to add those templates, like we add UDF, same methodology, it will speed up the whole process.
5. What business value would your suggestion represent for your organization?
Most of projects (not only in our organization, or only metal stamping tools), are created by using lot of templates. So if the whole process of inserting  templates, be simplified, easy to use and replicate those templates. The whole project will be faster and reliable.
1 Comment
olivierlp
Community Manager
Thank you for your idea and the information provided.
