I would like to be able to create an integer parameter with a blank value until it has been defined. Zero is a valid value and I would like to not have a value assigned until the object has been reviewed and the correct value determined. After the value has been entered there is no need to be able to go back to a blank, but it would be nice to be able to have an initial value of NULL.
